Easy Wood Tools Ci7-NR Carbide Cutter - Diamond Negative Rake
109301
109301
From £24.48 £20.40
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Fits: Micro Easy Detailer and Mid-Size Micro Easy Detailer.
  • 8.3mm wide, solid carbide
  • Negative rake for acrylics, resin and very hard woods
  • Optimum grade of carbide, long lasting cutting edge
  • Proprietary grinding for the sharpest edge possible
  • Precision ground finish
  • Easy Wood Tools tips are 100% made in the USA
The Ci7-NR solid carbide, negative rake tip is diamond shaped, 8.3mm wide. It fits the Micro Easy Detailer and Mid-Size Micro Easy Detailer.
Negative Rake Carbide Cutters virtually eliminate chipping and catches when turning resins, acrylic, and other man-made materials. Excellent results when turning very hard woods, and very smooth finishing cuts. Very effective for hollowing, allowing for smooth catch-free passes.
When one portion of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
