Easy Wood Tools Mini EASY HOLLOWERâ„¢ #1
- Turn ornaments, mini vases, and other small hollow forms
- Mini Hollower #1 removes bulk of the waste
- Negative Rake Carbide Cutter minimises the risk of a catch
- Square section shaft provides excellent stability
- Carbide cutter keeps its edge many, many times longer than HSS
- No need to sharpen; simply rotate cutter to a fresh edge
- American Maple handle with copper ferrule for strength
- Easy Wood Tools are 100% made in the USA
Easy Wood Tools Ci5-NR Carbide Cutter - Round Negative RakeFrom £20.88 £17.40 -
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)From £18.28 £15.23
The Easy Wood Tools Mini Easy Hollowerâ„¢ #1 is a carbide woodturning tool designed for removing the bulk of material from the interior of small hollow forms and bowls.
As the first stage in the Mini hollowing system, it is ideal for opening up the centre of small vessels, boxes, and light hollow forms, where control and visibility are key.
Fitted with a replaceable carbide cutter and a rigid hollowing shaft, the Mini Easy Hollowerâ„¢ #1 offers excellent stability when working inside smaller forms.
Its compact yet more substantial size than Micro tools provides a reassuring balance between control and capability, while the flat tool support ensures it sits securely on the rest.
With no sharpening required, it simplifies hollowing for both beginners and more experienced turners.
The Mini Easy Hollowerâ„¢ #1 is designed for efficient, controlled bulk removal inside smaller workpieces, allowing you to quickly establish the internal cavity.
Its shaft design provides the stiffness needed to reduce chatter while working inside the form, and when used parallel to the floor at centre height, the tool remains stable on the rest. This helps to minimise catches and maintain predictable cutting action as you begin the hollowing process before moving on to #2 and #3 for refinement.
Easy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.
The shaft is engraved with the corresponding carbide cutter reference number for easy identification.
Specifications
Tool type: Mini carbide hollowing tool (#1 – bulk removal)
Cutter type: Carbide hollowing cutter
Range: Mini (compact tools for small hollow forms)
Shaft design: Hollowing shaft for internal access and stability
Handle: Hardwood with copper ferrule
Negative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to achieve smoother cuts and greater control when hollowing delicate or dense materials.
| Chisel Blade Length | 82 mm |
| EAN Barcode | 811269021145 |
| Handle Length | 305 mm |
| Overall Length | 380 mm |
| Replacement Tip | Ci5-NR (109317) |
