Everbuild Mitre Fast Bonding Kit is a two-part cyanoacrylate adhesive system offering almost instant results. It comprises the adhesive and an aerosol activator. Apply the adhesive to one surface, spray the activator on the other surface. Bring the two together and hold for about 10 seconds. Voila, it’s stuck.
Everbuild Mitre Fast has proved particularly useful in situations such as kitchen fitting for mitre joints on cornices and pelmets. The almost instant setting time allows for rapid progress, dramatically reducing assembly times when compared to conventional wood adhesives. The high viscosity adhesive has less tendency to soak into porous surfaces ensuring greater bond strength compared to standard cyanoacrylates. Suitable for bonding of wood, MDF, chipboard, ceramics, rubber, PVCu, metals etc.
2-part cyanoacrylate adhesive, bonds in 10 seconds
Short setting time allows for rapid progress
Dramatically reduces assembly times
High viscosity adhesive ensures good bond strength
Pack contains 50g adhesive & 200ml activator
Suitable for bonding of wood, MDF, chipboard, ceramics etc
