Lee Valley Right Angle Assembly Clamps (Pkt 2)
- Made from glass fibre reinforced nylon
- Single handed ratchet mechanism
- Hold boards or panels from 10 mm to 20 mm thick at 90°
Dry assembly of a carcass or even trying to hold two panels together to place a fixing screw often leads to much cussing and the desire for a third or even fourth hand. Right-Angle assembly clamps are that third and fourth hand, made from glass fibre reinforced nylon they have a single handed ratchet mechanism allowing them to be squeezed together across a corner, providing a firm hold. The clamps hold boards or panels from 10 mm to 20 mm thick at 90°, with a variation of up to 6mm in thickness between the panels. Ideal for picture framing, test fitting, holding whilst applying cramps or placing a fixing. Overall size 100 mm x 75 mm x 40 mm, sold in pairs.
EAN Barcode | 5052511006168 |
Max Material Thickness | 20 mm |
Model | 50K38.01 |
