Everbuild Power Pro Sealant Gun
108835
108835
- Heavy-duty, takes 310ml and 400ml cartridges
- Extra pull trigger for long smooth run of sealant
- Cartridge holder rotates for easy access in tight spots
- Hook end plunger rod for hanging on a ladder rung
Everbuild Lumberjack 5 Minute Polyurethane Wood Adhesive GelFrom £8.58 £7.15
Show more
Show less
A heavy duty sealant gun for professional users. It will take both 310ml and 400ml cartridges. This sealant gun features an extra pull trigger helping you achieve a long smooth run of sealant for a good result. The cartridge holder rotates allowing you to find the best ‘angle of attack’ in tight spots. The end of the plunger rod is bent to form a hook for hanging on a ladder rung when working at height and makes it easy to store the sealant gun when not in use.
EAN Barcode | 5029347600945 |
