This Faithfull Wire End Brush is perfect for cleaning metal surfaces prior to welding or painting, or for light-medium applications. It is circular and has a flat end, making it perfect for use in hard-to-reach areas. It has a 0.3mm crimped steel wire finish. The brush has a 6mm shank and will operate with power tools with a maximum speed of 4500rpm.
Size: 25mm diameter x 6mm shaft x 0.3mm wire size. Conforms to ISO9001 & DIN EN1083-1 and 2.
