These FEIN E-cut blades are a combination of the proven performance of Japanese style saw teeth and the longevity of bi-metal. The result is greater strength, wear resistance, speed and outstanding results even in hardwood. Bi-metal gives you three times the tool life of standard E-cut blades. The special saw blade geometry allows you to make plunge cuts with greater control. The blade measures 50mm length x 65mm cutting width.
The FEIN Starlock (patented) oscillating multi-tool mounting system overcomes the disadvantages found with previous designs. Starlock sets the new standard in the oscillating multi-tool market. The design greatly improves the transmission of torque from the motor to the blade tip. No more wasted power means faster working, minimised vibration and better results. Looking rather like a crown bottle top, the raised portion of the Starlock snaps into the next generation of multi-tools, making the system truly tool-less.
