Festool Multi-Jetstream2 Pad For RO 150 FEQ Sander
- Designed for maximum suction power, even near edges
- Virtually 100% efficient, for clean and healthy working environment
- High temperature-resistant for long service life
- StickFix system for fast abrasive changes
- Pads available in H/D hard or soft
- Super soft pad available for curved and contour sanding
- Supplied singly
The patented Multi-Jetstream2 pad guarantees outstanding sanding results thanks to its unique design.
Multi-Jetstream2 pads guarantees virtually 100% dust extraction for a consistently high material removal rate. These 150mm diameter Multi-Jetstream2 pads fit the Festool RO 150 FEQ-Plus Rotex sanders. They feature StickFix hook and loop system allowing quick and easy changing of abrasive discs.
The pads are available in hard and soft for general sanding, and an ultra soft version designed for sanding rounded and contoured surfaces. Supplied as a single pad only.
