Festool TCT Saw Blade Laminate/HPL - 160mm x 2.2mm x 20mm 48T
489457
489457
- 160 x 20mm Festool saw blade suitable for the TS55
- Triple chip ground teeth for exceptional finish
- Fine cut for laminates and HPL 48 teeth
A 160 x 20mm Festool saw blade suitable for the TS55 plunge saw, with a 2.2mm kerf. This blade has 48 teeth with a triple chip grind giving you a fine cut on laminate costed boards, HPL (High Pressure Laminate) melamine resin boards (Trespa ®), mineral materials, acrylic glass and phenolic-resin-bonded fibre and fabrics.
