Festool HBS Wood Saw Blade for Multi-Tool 100mm
111681
From £84.98 £70.82
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Perfect for long, straight cuts and ideal for cutting out parquet and laminate
  • Made from high-quality bimetal, it's built to last
  • Features adjustable grip protection for safety
  • Simple, tool-free saw blade replacement
  • Diameter of 100mm
  • StarLock fitting for fast efficient blade changes
  • Compatible with Festool OSC 18 multi tools and other multi tool brands
The Festool HBS 100mm wood saw blade is the perfect tool for long, straight cuts. With its all-around toothed design, it's ideal for cutting out parquet and laminate, especially when used with the depth stop.
Made from high-quality bimetal, this multitool is built to last. It features an adjustable grip protection to prevent injuries, ensuring you can work safely and confidently. With its precise cut-outs, it's the perfect addition to your toolkit.
Designed to work seamlessly with the depth stop and sliding shoe, creating a perfect system for all your cutting needs. And with its simple, tool-free saw blade replacement, you can get back to work quickly and easily.
With a diameter of 100mm and grip protection for straight, long cuts, this circular saw blade is built to last, thanks to its high-quality bimetal construction. Add the HBS wood saw blade to your toolkit today and experience the difference for yourself. This blade is suitable for Festool, Bosch, Fein and other Multi-Tools that can take StarLock fitting accessories.
