Festool MINI T-LOC Systainer Case
503826
503826
- Smallest T-Loc case
- Quality design to protect the contents
- T-LOC system case for ease of use
- T-LOC central control, Lock, Open Control
- Robust plastic construction with moulded-in ribs for strength
- Mini cases can stack and clip together
- 265 x 171 x 70 mm
The Mini Systainer® case is the smallest of the Festool storage cases and now incorporates the clever single T-LOC central control, which stands for Lock, Open Control - performing three functions in one. Twist to close the lid tight and cases lock securely together in seconds. They can be stacked and opened while in the stack, are designed to keep the contents safe and to make transportation easy. The case is 265mm wide x 171mm deep front to back and 70mm high. N.B. Cannot be connected to T-LOC SYS 1, SYS 2, SYS 3, SYS 4, SYS 5 or SORTAINER.
