Festool Rubin 2 Abrasive Discs 125mm (Pkt 10)
AX849181
AX849181
- High-performance aluminium oxide abrasive for wood
- Final sanding for varnishing, preparatory sanding for oiling or waxing
- Enhanced extraction when used with and extractor
- Helps achieve consistent smooth surface finish
- 125mm diameter
- Supplied in packs of 10
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.18 £10.98
Show more
Show less
Festool high-performance 125mm diameter sanding abrasives for wood materials. Suitable for the Festool RO 125, ETS 125 & LEX 125 sanders. Supplied in packs of 10.
Abrasive Backing | Paper and Hook and loop |
Abrasive Disc Diameter | 125 mm |
Abrasive Type | Rubin 2 |
