USE CODE: BLACKFRIDAY TO SAVE 10% SITEWIDE*
Festool Sanding Pads ST-STF ES125/90/8
930880
930880
- For use with the Festool ETS 125 Sander
- 125mm diameter, M4 Connecting thread
- 90mm jet stream hole diameter
- Soft Version for universal use on plain and arced surfaces
Festool sanding pads for the Festool ETS 125 Sander. 125mm jet stream pad, M4 connecting thread and 90mm jet stream hole diameter. For universal use on plain and arced surfaces. High temperature durability burr. For robust use with grits up to P220.
