Festool Sort Systainer With Compartments (DOMINO)
- Features 3 internal, removable trays and 8 dividers
- Ideal for storing parts, accessories or tools
- Robust ABS moulding construction with reinforcing ribs for strength
- Cases stack and clip together
- 396mm long x 296mm wide x 105mm high
This empty Systainer SYS 1 T-LOC contains 3 removable trays with flexible compartment division along with 8 slot-in dividers. Originally designed for the DOMINO parts these are just as useful for other accessories, small parts or tools.
T-LOC Systainer® cases incorporate a clever single T-LOC central control. This has 3 functions: to lock the lid, to connect other Systainer cases securely together and to open the lid even when locked to other cases.
Made of robust ABS plastic, the case features moulded-in ribs to further strengthen and reinforce the box. The large top handle folds into a recess in the lid when not in use, leaving a flat top.
The case is 396mm x 296mm x 105mm. All Systainer cases are sturdy and impact-resistant as well as dust and splash-proof.
