FISCH Tapered Plug Cutters
From £16.58 £13.82 was £19.58 £16.32 Save £3.00 £2.50
  • Make tapered plugs for a perfect fit every time
  • Use to hide screw heads of to add decoration
  • 4 cutting edges for smooth sided plugs
  • For use in pillar drill or drill stand
  • Cutting depth 18mm, 10mm shank
A perfectly round plug with a slight taper makes for a perfect fit every time. Even the most carefully drilled holes can be fractionally oversized. These four flute plug cutters from FISCH cut plugs that taper in their length. The taper is just sufficient to ‘take up any slack’. Tap the plug into the hole for a snug fit and trim any excess with a flush cut saw. Using the same timber and matching the grain direction results in an almost invisible finish. Use a contrasting timber for a decorative finish.
The plug cutters have four sharp cutting edges producing clean smooth sided plugs. Made from Chrome Vanadium tool steel for a long tool life. For the best result use a drill press or drill stand. The optimum speed is 1,000 rpm softwood or 500 rpm in hardwood. Cutting depth 18mm.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.30 6
