Flexipads Sanding Pads
AX835839
AX835839
- High quality durable sanding pads
- Available in 25, 50 & 75mm diameter
- Helps to eliminate sanding marks
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)Special Price £12.38 £10.32 was £14.38 £11.98 Save £2.00 £1.67
Show more
Show less
The power sanding of bowls is a fast, efficient way of achieving an excellent surface ready for applying a finish of your choice. These high quality pads are very durable and have just the right amount of flexibility to mould themselves to the contours of your bowls. Available in 25, 50 and 75mm diameters with the option of a conical shaped 50mm version which can give better access in certain applications. The 25mm pad has a 3mm shank and the larger sizes 6mm.
