freud LU1B Saw Blade - 450mm x 4.2mm x 30mm 32T
108344
Special Price ÂŁ124.18 ÂŁ103.48 was ÂŁ137.98 ÂŁ114.98 Save ÂŁ13.80 ÂŁ11.50
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Hi-Density Industrial Carbide teeth for long life
  • Rip or crosscut; soft and hard solid wood
  • ATB tooth format for clean cuts
Freud’s industrial circular saw blades are designed for cutting solid wood, wooden panels and manmade boards. The blades are designed to deliver; high performance, a quality finish and longevity.
The superior performance of these saw blades comes from several unique features. Silver I.C.E, is a specifically engineered coating that is heat resistant and protects against resin build-up and corrosion. Anti-vibration slots offer a flawless finish, stabilising the blade and reducing chatter. Expansion slots dissipate blade stress and reduce noise. Each blade type within the range uses a specific grade of freud’s own Hi-Density Carbide; matched to the blades intended use. This carbide enables the carbide teeth on Freud's blades to last up to four times longer than standard products.
These blades deliver outstanding finishing even under extreme working conditions.
