This high precision digital readout caliper has a very robust all stainless steel construction. Use for internal, external, step and depth measurements. Accuracy is 0.01mm or 0.001" and maximum measuring distance 155mm or 6". Zero can be set at any point along the range, and the display is easily switched from a metric to an imperial reading. It takes a standard SR44 battery (supplied). N.B. Philips 00 screwdriver required for battery compartment.
Robust stainless steel construction
High precision digital readout
Imperial or metric display at the touch of a button
