Invest in tools that are built to last with this 6 piece carving set from Henry Taylor.
Built to last
Synonymous with quality, Henry Taylor has produced a carving set that will not fail to impress. This super sharp set of six carving chisels are perfect for a range of carving tasks but ideally suited to fine detailed carving and for linoleum or wood block cutting.
Everything you need
This handy set contains:.
5/16"(8mm) bent chisel for concave curves or around a hard to reach area
5/16"(8mm) shallow gouge with a gentle curve for shallow cuts
3/8"(9mm) bent skew for those hard to reach, fiddly spots
3/8"(9mm) straight chisel for cutting flat or convex curves
1/8"(3mm) bent vee tool for outlining lettering or leaving a clean crisp edge
Carve in comfort
Each chisel is 140mm long and features a rounded, hardwood handle for fine grip and comfort in the palm of your hand.
The Super Sharp set of six has been selected for fine detailed carving and for linoleum or wood block cutting. The hardwood handles are designed to fit comfortably into the palm of the hand. All chisels are 5.1/2"(140mm) long and the set contains a 5/16"(8mm) bent chisel, a 5/16"(8mm) shallow gouge, a 3/8"(9mm) bent skew, a 3/8"(9mm) straight chisel, a 1/8"(3mm) deep gouge and a 1/8"(3mm) bent vee tool. Supplied in a plastic wallet.
