Hermes BW 110 Abrasive Belts 150 x 2,260mm
- Aluminium oxide abrasive on E-weight paper backing
- Semi-open coating, antistatic resin bonded, reduces clogging
- Economical sanding for excellent results on all types of wood
Axminster Workshop Abrasive Belt Cleaner - Large (300 x 50 x 50mm)From £30.28 £25.23
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.68 £11.40
The aluminium oxide abrasive on an E-weight paper backing has a semi-open structure with antistatic properties to reduce clogging. BW110 is especially suited to sanding hardwoods and is suitable for use on metal. It has a good stock removal rate even with low sanding pressure. BW110 is an excellent multi-purpose abrasive for use with powered sanders.
To fit Jet OES-80 CS oscillating edge sander and the Axminster AT 6X90 oscillating belt sander.
Abrasive Backing | Paper |
Abrasive Belt Length | 2,260 mm |
Abrasive Belt Width | 150 mm |
Abrasive Type | BW 110 |
