Hermes RB 377 YX Abrasive Belts 75 x 2,000mm
From £9.98 £8.32
1 Review
  • Polyester/cotton cloth backed aluminium oxide abrasive
  • High stock removal rates in the coarse grit range
  • Consistent surface quality in the fine grit range
Available in either 60g or 100g, these Hermes RB377YX belts are suitable for the Axminster Engineering Series BS-75 Belt Linisher. The RB377YX material is a heavy and semi-flexible aluminium oxide abrasive cloth. The special aluminum oxide grain mix provides high stock removal in the coarse grits and gives a very constant surface quality in the finer grit ranges, the backing is a polyester/cotton cloth which ensures smooth running on our machines. All this makes it a perfect partner for our range of belt linishing machines whether you are using steel, stainless steel, aluminum or other types of non-ferrous metals.
5.00 1
