Hermes RB 377 YX Abrasive Belts 100 x 560mm
AX19637
AX19637
- Aluminium oxide, resin bonded on a cotton/polyester cloth
- Consistent surface coating for the best possible finish
- Suitable for wood, metal, lacquer and composite
Axminster Workshop Abrasive Belt Cleaner - Large (300 x 50 x 50mm)From £30.28 £25.23
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.68 £11.40
Show more
Show less
High quality, heavy duty abrasive belt. Aluminium oxide coated resin bonded on a cloth backing giving a constant surface coating for the best possible finish. Suitable for wood, metal, lacquer and composite. Very strong secure belt join for long life.
Size 100 x 560mm to fit a range of belt sanders including Elu MHB90, Skil 1400, AEG BBS1100.
Abrasive Backing | Cloth |
Abrasive Belt Length | 560 mm |
Abrasive Belt Width | 100 mm |
Abrasive Type | RB 377 YX |
