Hermes BW 110 Resin Bonded Abrasive Roll 115mm x 10m
- Aluminium oxide abrasive on heavy E-weight paper backing
- Semi-open coating, anti-static resin bonded reduces clogging
- Economical sanding for excellent results on all types of wood
Axminster Workshop Abrasive Belt Cleaner - Large (300 x 50 x 50mm)From £30.28 £25.23
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.68 £11.40
An economical way to purchase abrasive for orbital sanders. An aluminium oxide abrasive on an E-weight paper backing, the heavyweight paper reduces breakage at the securing point on orbital sanders. BW110 has a semi-open structure with antistatic properties to reduce clogging. It is especially suited to sanding hardwoods and is suitable for use on metal. It has a good stock removal rate even with low sanding pressure. BW110 is an excellent multi-purpose abrasive for use with powered sanders.
Available in a variety of grits.
Abrasive Backing | Paper |
Abrasive Roll Length | 10 m |
Abrasive Roll Width | 115 mm |
Abrasive Type | BW 110 |
