Lamello Cabineo 8 M6 Panel Connector Starter Kit
106755
From £114.98 £95.82
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Cabineo 8 M6 for connections in wide variety of materials
  • Efficient machining and faster assembly
  • Surface machining, no edge drilling necessary
  • Cabinets shipped flat-packed with connectors pre-installed
  • Accurate, fast assembly with a cordless drill
  • Includes 80 x Cabineo 8 M6 connectors, 40 x white cover caps, 40 x insert nuts, 1 x installation tool and 1 x Cabineo 1/4" hex driver bit
Book your demonstration
Lamello products are renowned for their precision and quality, saving you time and money with outstanding results. Our knowledgeable and friendly team are available to demonstrate the Lamello range in person or via a video call. You can see the tools in use and ask questions before placing your order.
The Cabineo starter set Includes 80 x Cabineo 8 M6 connectors, 40 x white cover caps, 40 x insert nuts, 1 x installation tool and 1 x Cabineo 1/4" hex driver bit.
Made to withstand vigorous use, the design possibilities are endless. Cabineo offers a discreet, fast and effective solution to join heavy-duty materials without compromise. The Cabineo 8 M6 allows you to make time and cost saving connections in a variety of materials. Connections can be made with aluminium, steel or HPL materials, as well as timber and man-made boards. The Cabineo 8 M6 boasts the same impressive credentials as the existing Cabineo family. The one-piece connector is quick and easy to install into a drilled or routed shape and requires no edge drilling and has a high clamping force.
Installing the Cabineo into the workpieces during the production process is possible, as there are no protruding parts, which could damage the finished surfaces. In addition,this eliminates the need for bags of separate loose fixings. Because the elements are already factory-installed, assembly is greatly simplified and considerably faster.
