This is an industrial CNC milling cutter 12mm diameter. The CNC cutting of the recess for the Cabineo body can be done either from the top with a 15mm CNC drill bit or from the side using a CNC milling cutter.
Lamello produce the drill and a choice of cutters to suit the requirements of a variety of CNC machines. Fully dimensioned drawings are available for programming the CNC machine for each of the milling cutters and the drill option.
