Lamello Clamex P-14 Zeta Connector
From £107.88 £89.90
  • Unique fitting to overcome many design problems
  • Clamps, locking joint in place and is also detachable
  • No glue or screws are required, simple assembly
  • Only visible sign of joint is a single 6mm hole
  • Special ‘T’ slot needs to be cut by Lamello Zeta biscuit jointer
  • Joint angles 30° – 180°
  • Made from fibreglass reinforced plastic with zinc die-cast lever
  • Suitable for solid wood, composite boards and other sheet materials
Book your demonstration
Lamello products are renowned for their precision and quality, saving you time and money with outstanding results. Our knowledgeable and friendly team are available to demonstrate the Lamello range in person or via a video call. You can see the tools in use and ask questions before placing your order.
This is a truly amazing connector with a host of uses. Lamello has overcome many design assembly problems with this clamping connector; it is almost totally invisible, only a single 6mm hole shows. The Clamex P is a biscuit shaped fitting with a ‘T’ profile that slides in place, no screws or glue are needed. Having a pivot lever and two alignment studs, this lever is driven using a hexagon key though the 6mm hole, locking the fitting together forming a very secure joint. Ideally suitable for connections up to 45° in 18/19mm panels and for 90° connections in 16mm panels. The required slot is cut using a Lamello Zeta biscuit jointer specially developed for this application, cutting the slot and adding the ‘T’ to the bottom using a unique vertical mechanical drive. Made from fibreglass reinforced plastic, lever zinc die-cast for strength (tensile fitting strength 1000N = 100kg). Overall length is 66mm x width 27mm, each half has a depth of 14.5mm and it is 7mm in width (9.7mm o/a with ‘T’). Supplied as a pack of 80, 300 or 1000.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.90 13
