From £107.88 £89.90
  • Unique fitting to overcome many design problems
  • Medius centre panel connector, 2 connectors will work back to back
  • Minimum 16mm thick central panel (30mm max)
Customers Also Bought
This special connector is for the Lamello Zeta jointer. The Medius is a centre panel connector, allowing you to put them back to back in a board with a minimum thickness of 16mm (max 30mm). The Zeta and Clamex P system allows you to overcome so many jointing problems, forming a strong almost invisible joint that requires no clamping and is also detachable. This is a truly amazing connector with a host of uses. The Medius is a 2 piece biscuit shaped fitting with a 'T' profile that slides in place, no screws or glue are needed. Having a pivot lever and two alignment studs, this lever is driven using a hexagon key though the 6mm hole, locking the fitting together forming a very secure joint. The required slot is cut using a Lamello Zeta biscuit jointer specially developed for this application, cutting the slot and adding the 'T' to the bottom using a unique vertical mechanical drive. Overall length is 66mm, one half has a depth of 13.5mm, the other 8mm, it is 7mm in width (10mm o/a with 'T').
  • Clamps, locking joint in place and is also detachable
  • No glue or screws are required, simple assembly
  • Only visible sign of joint is a single 6mm hole
  • Special 'T' slot needs to be cut by Lamello Zeta biscuit jointer
  • Joint angles 30 – 180 Suitable for solid wood, composite boards & other sheet materials
