From £135.78 £113.15
Out of Stock
  • Very clever multifunctional drill jig
  • Make precise dowel joints, no need to mark or measure
  • Align plate using pins, insert bush and drill.
Customers Also Bought
This is a very clever jig and will allow you to very accurately position holes in the exact place and reposition on an opposite member if required for dowelling. Simple to look at and use the secret is in the precision with which the jig has been made that ensures accurate hole position every time.
A network of holes in the jig and pins are used as reference stops against your work so no matter what the shape the hole position can be repeated. Simply choose the correct drill bush and screw this into the jig so that it will guide your drill bit. Once drilled, remove pins and bushes, relocate in the same holes, protruding from opposite side of the plate, this then guides the plate and drill in place for an exact mirror hole position. The Basic kit contains; Drill plate, 3 guide pins, 4 drill guides 6, 8 10 and 12mm and fixing screw.
  • Exact transfer of hole position to matching components
  • Guide plate with multiple holes to position jig using pin stops
  • Idea for shaped profiles such as dowelling handrails
  • Joining bar for longer hole spacing, end stop available
  • Drill bushes screw securely in plate and guide drill bit
  • Basic kit contains, Drill plate, 3 guide pins
  • 4 drill guides 6, 8 10 & 12mm and fixing screw
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
