Lamello Simplex KD Fittings
AX22532
AX22532
- Aluminium jointing element
- Joint can be taken apart
- Fits standard No. 20 biscuit joint
Show more
Show less
The Lamello Simplex system is an aluminium jointing element designed for any application where the joint may need to be taken apart from time to time, such as radiator concealments, screens or furniture parts etc. The size of the joint to be cut is identical to that of a No. 20 biscuit. These fittings should be glued into the recess using a 2 part Epoxy glue.
