Mafell KSS 60 18M bl Cross Cut Saw 18V (Body Only)
107743
Special Price £944.98 £787.48 was £1,049.98 £874.98 Save £105.00 £87.50
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
  • Cordless, portable crosscutting system
  • Precision angle cuts from -60° to +60°
  • Simple press of a button detaches saw from the rail
The KSS 60 cordless circular saw includes a crosscut guide rail track for cuts up to 408mm in length. The saw and rail form an accurate and extremely portable crosscut system for square or mitre cuts. You can expect a level of accuracy normally only achieved using a large mitre saw. Add to this the convenience of a cordless machine, it makes the KSS 60 an excellent option for the workshop or on site as an alternative to a static mitre saw.
With the machine attached to the crosscut guide rail track, one fixed and one adjustable stop on the underside of the rail allows precision angle cuts from -60° to +60°. After cutting the track automatically returns to the starting position ready for the next cut. Max cutting depth at 90° with guide rail: 61mm, at 45°: 47mm. Fitted with FLIPPKEIL, you no longer have to detach the riving knife when making plunge cuts.
A simple press of a button allows you to remove the saw from the rail and take full advantage of the benefits of a cordless circular saw.
Compatible with all Mafell Guide rails
Note: Supplied as Body only without batteries and charger. Part of Mafell 18V range.
Supplied with: Crosscut rail 400, TCT saw blade 185mm x 32t, Parallel guide fence, Dust bag.
Warranty Mafell 3 Year Warranty (Registration Required)
Register on the Mafell website and select NMA Agencies, Brighouse from Dealer options.
In case of a warranty claim please contact NMA Agencies NMA Customer Service Team on - Tel: 01484 400488
For warranty issues outside of the UK, tools must be returned to the UK at the customer's own cost.
Register now
