The KSS 60 cordless circular saw includes a crosscut guide rail track for cuts up to 408mm in length. The saw and rail form an accurate and extremely portable crosscut system for square or mitre cuts. You can expect a level of accuracy normally only achieved using a large mitre saw. Add to this the convenience of a cordless machine, it makes the KSS 60 an excellent option for the workshop or on site as an alternative to a static mitre saw.
With the machine attached to the crosscut guide rail track, one fixed and one adjustable stop on the underside of the rail allows precision angle cuts from -60° to +60°. After cutting the track automatically returns to the starting position ready for the next cut. Max cutting depth at 90° with guide rail: 61mm, at 45°: 47mm. Fitted with FLIPPKEIL, you no longer have to detach the riving knife when making plunge cuts.
A simple press of a button allows you to remove the saw from the rail and take full advantage of the benefits of a cordless circular saw.
Compatible with all Mafell Guide rails.
Supplied with: 2 x 18V, 5.5Ah Li HD (high definition) batteries, air cooled charger, Guide rail 400, TCT saw blade 185mm x 32t, Parallel guide fence, Dust bag and metal carrying case (785 x 320 x 285mm).
Note: Charger fitted with UK 3-pin plug.
18V cordless, portable crosscutting system
Precision angle cuts from -60° to +60°
Simple press of a button detaches saw from the rail
