Mafell P1 cc Jigsaw Kit with Rail & Tilt Base Kit 230V
720783
From £699.98 £583.32
3 Reviews
Out of Stock
  • Precise true cuts on straight and curved work
  • With Tilting base ±45° and 800mm Guide Rail
  • Unique built-in dust extraction
In addition to the standard equipment this version includes the Tilting Base for exact bevel cutting ± 45° and an 800mm Guide Rail F 80. The Tilting Base simply clips onto the jigsaw replacing the standard base. The 800mm Guide Rail ensures clean and exact straight cuts. The upper surface of the rail has a special coating, which helps the jigsaw glide along whist a rubber edge strip provides tear protection.
Equipped with a Cuprex compact motor that delivers 900W of power and intelligent digital electronics to maintain speed under load, the P1 cc offers cutting depths up to 115mm. The base plate is compatible with other accessories in the Mafell F guide rail system for even greater cutting precision. The dust extraction uses the Venturi principle to maximise effectiveness and ensure the cut-line is free from debris at all times, even without attaching a vacuum extractor. The speed can be varied in a range from 800 to 3,000 strokes/min. With three oscillation settings and a zero setting, rapid progress in a wide variety of materials is assured.
The P1cc is compatible with Mafell Guide Rails and takes all standard bayonet fitting jigsaw blades, as well as the unique patented Mafell CUnex precision blades with a wedge shape design and extra strength.
Supplied with: Tilting base (P1 SP), 800mm Guide Rail (F 80), 3x jig saw blades (CUnex W1, W2 & W+P2), Base plate (P1-GP), Parallel fence (P1-PA), Hose connector (P1-AS), Chip deflector (P1-SA), Splinter guard (P1-SS), Glider (P1-G) and T-MAX case.
Warranty Mafell 3 Year Warranty (Registration Required)
Register on the Mafell website and select NMA Agencies, Brighouse from Dealer options.
In case of a warranty claim please contact NMA Agencies NMA Customer Service Team on - Tel: 01484 400488
For warranty issues outside of the UK, tools must be returned to the UK at the customer's own cost.
Register now
5.00 3
