Bosch T308B Jigsaw Blades Clean Wood Cutting
AX724826
AX724826
- Fast clean cutting on both sides of work
- Two rows of different style teeth
- Scalpel tooth and Pointed tooth
- Softwood cutting
- Available in packs of 5 or 25
Bosch T101BR Jigsaw Blades Reverse Cutting For Wood (Pkt 5)From £7.58 £6.32
Bosch T101AO Jigsaw Blades Tight Curve Cuts in Wood (Pkt 5)From £6.68 £5.57
Bosch T101A Jigsaw Blades Acrylic & Perspex Cutting (Pkt 5)From £13.68 £11.40
Show more
Show less
Clean accurate and tear free on both sides of the wood. Two rows of teeth arranged at different angles, a razor sharp scalpel tooth will cut the wood fibres on the reverse whilst a precision ground pointed tooth separates the wood fibres on the top surface and give super clean cuts.
Blade Type | HCS, Ground |
Jigsaw Blade Length | 91 mm |
Jigsaw Blade Type | Clean Cuts |
Max Cutting Depth | 50 mm |
Model | T308B |
Tooth Pitch \ tpi | 2.20 mm \ 11.5 tpi |
