Makita DHR171Z Brushless Compact SDS+ Drill 18V (Body Only)
- Online exclusive
- Compact and powerful, only 273mm front to back
- Rotation only or hammer with rotation for multiple applications
- Variable speed trigger with reverse
- Built-in L.E.D light illuminates the work area
- Vibration absorbing handle for comfort and control
- Energy efficient brushless motor for longer battery runtimes
- Supplied with auxiliary handle and depth stop
Axminster APF 10 Evolution® Powered Respirator with Impact VisorFrom £299.98 £299.98
The Makita DHR 171 SDS Plus rotary hammer drill is a powerful, compact tool, ideal for work in tight spots. Its size (only 273mm front to back), weight and balance make it a great choice when working overhead.
It features the latest Makita brushless motor for a long and maintenance free working life. These motors are highly efficient and result in battery runtimes up to 50% longer compared to an equivalent brushed motor.
The DHR 171 has two operating modes: rotation with hammer for rapid drilling into concrete and masonry or rotation only for metal or wood. Whatever the material, this unit gives fast and efficient results without the inconvenience of a trailing mains cable.
Additional features include a vibration-absorbing handle, variable speed trigger with forward and reverse and a built-in L.E.D spotlight.
This is a body only tool and is compatible with Makita 18V LXT batteries. Supplied with auxiliary handle and depth stop.
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
- Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
- The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
Batteries Included | Body Only Tool |
Battery Type | Li-ion |
Battery Voltage | 18 V |
Chuck Type | SDS Plus |
Corded or Cordless | Cordless |
Drilling Speed | 0 - 680 rpm |
EAN Barcode | 0088381848503 |
Impact Energy | 1.2 joules |
Impact Rate | 0 - 4,800 /min |
Max Drilling Concrete | 17 mm |
Max Drilling Metal | 10 mm |
Max Drilling Wood | 13 mm |
Model | DHR171Z |
Nett Weight | 2.8 kg (with battery) |
Rating | Trade/Professional |
Reverse | Standard Feature |
Rotation Only | Standard Feature |
Sound Power Level LwA [Uncertainty K] | 97 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 86 dB(A) [3.0 dB] |
Vibration Drilling Concrete [Uncertainty K] | 9.0 m/s² [1.5 m/s²] |
Vibration Drilling Metal [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
