Makita HS7601J 190mm Circular Saw
101601
From £147.98 £123.32
12 Reviews
Low Stock - Ready to dispatch
  • 1,200W high specification, powerful motor
  • Heavy-duty aluminium baseplate
  • Rubber moulded grip handle for comfort
  • Single action lever for depth adjustment
  • Aluminium die-cast blade guard
  • Flat motor housing for stable and easier blade change
  • 3 year Makita warranty available (registration required)
  • Supplied with a 12tpi TCT saw blade, rip fence, dust extraction nozzle, hex key wrench and MAKPAC (Type 4) connector case and inlay
This thoughtfully designed 190mm saw allows you to cut to a maximum of 66mm. It has a 1,200W high specification and powerful motor. The flat motor housing lets the saw stand upright and stable when changing the blade. The heavy-duty base, cut from aluminium plate, forms a solid base adding to the overall quality. Depth adjustment simplified using a single action lever. The rubber moulded grip greatly increases comfort when in use. The guarding is die-cast aluminium.
This product is manufactured in the UK, at the Makita factory in Telford.
Supplied with general purpose 12tpi TCT saw blade, rip fence, dust extraction nozzle, hex key wrench and MAKPAC (Type 4) connector case and inlay.
Warranty Makita 3 Year Warranty (Registration Required)
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
  • Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
  • The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
4.80 12
