Makita LS1019L 260mm Compound Mitre Saw With Laser
- Unique twin guide-rail design allows use flush against a wall
- Innovative motor mounting increases vertical capacity
- Front bevel lock for easy, convenient adjustment
- Laser line-of-cut adjustable for left or right of blade cutting
- Large dust collection port for excellent extraction performance
- Soft start for smooth startups and longer gear life
- Electronic speed control maintains constant speed under load
- Mitres 0°-60° left and right; bevels 0°-48° left and right
- Indexed mitre stops: 0°, 15°, 22.5°, 31.6°, 45° and 60° (L or R)
- Large-sized aluminium base with pullout supports
Axcaliber Contract TCT Saw Blade - 260mm x 2.8mm x 30mm 60TFrom £36.38 £30.32
The Makita LS1019L dual-bevel sliding compound mitre saw combines capacity, accuracy and efficient dust extraction with a reduced footprint.
Its unique twin slide rails allow you to operate it flush against a wall. Rather than requiring space at the rear to accommodate the rails, the LS1019L fits perfectly on a workbench against a wall or confined spaces when working on site.
Power comes from a 1,510W direct drive motor with soft start. Electronic speed control maintains constant speed under load for smooth, high quality cuts. An electric brake brings the blade to an almost immediate halt on releasing the trigger. The angle of the motor mounting is one of the reasons this saw has a comparably larger capacity. The saw can cut mitres from 0° to 60° both left and right, with indexed stops at 0°, 15°, 22.5°, 31.6°, 45° and 60° (left or right). The bevelling capacity is from 0° to 48° both left and right. The bevel locking mechanism is conveniently located in the front of the saw giving you easy access for quick adjustments.
The built-in laser indicates the cutline and is adjustable to indicate the left or right side of the cutline whichever you prefer. The translucent blade guard gives better visibility of the blade when positioning the work.
A large, flexible dust collection port behind the blade helps provide effective extraction. The LS1019L includes a dust bag and a hose to connect to a vacuum extraction point. The saw’s large aluminium base features additional pull-out supports for more stable cutting.
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
- Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
- The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
Bevel Angle Range | 48° - 0 - 48° |
Blade Diameter | 260 mm |
Blade RPM | 3,200 rpm |
Bore Size | 30 mm |
Dust Collection | Dust Bag Supplied |
EAN Barcode | 088381843997 |
Electric Brake | Standard Feature |
Laser Class | Class 2 |
Laser Diode | 655 nm |
Max Bevel Cut @ 45º W x H | 310 mm x 42 mm or 279 mm x 58 mm |
Max Compound Cut @ 45º W x H | 218 mm x 42 mm or 197 mm x 58 mm |
Max Crosscut @ 0º W x H | 310 mm x 68 mm or 279 mm x 91 mm |
Max Mitre Cut @ 45º W x H | 218 mm x 68 mm or 197 mm x 91 mm |
Mitre Angle Range | 60° - 0 - 60° |
Model | LS1019L |
Motor Power | 1,510 W |
Nett Weight | 26.3 kg |
Overall L x W x H | 805 mm x 644 mm x 660 mm |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 101 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 91 dB(A) [3.0 dB] |
Spindle Lock | Standard Feature |
Vibration Cutting Wood [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
Voltage | 230 V |
