Micro-Mesh Flexi Files
502797
Special Price £1.81 £1.51 was £2.58 £2.15 Save £0.77 £0.64
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Flexible files for many uses
  • Micro-Mesh abrasive leaves a highly polished surface
  • Perfect for hobbies and crafts when deburring or polishing is required
Micro-Mesh is a unique cushioned abrasive that produces a very fine and uniform scratch pattern. Flexi Files are padded boards which are coated with Micro-Mesh. The design offers a gentle surface which helps to produce a smooth finish and a degree of flexibility allows the board to take the shape of the item being worked on.
2-way 16 x 150mm Flexi Files have a different grit on each side for rapid stock removal. Use to deburr, smooth and polish small metal areas.
100MX / 150MX - equivalent to 200/240 grit.
