The Mirka ROS650CV (Central Vacuum) and Mirka ROS650DB (Dust Bag) are 150mm air powered random orbital sander's with a 5.0mm orbit. This style of sander has a huge reputation for fine finishing, and Mirka products take the lead in this field. The ROS650CV is fitted with a central vacuum port which ensures completely dust free sanding when it's connected to a suitable extraction system. The ROS650DB is fitted with a dust bag system which ensure completely dust free sanding without requiring connection to an extraction system.These sander's are extremely light in weight, very well balanced and can be used for long periods. The speed can be regulated through a range of 4-12,000rpm. Suitable for use on all kinds of surfaces and capable of a very fine finish. Perfect for large furniture, work surfaces and vehicle use. 2+1 Extended warranty on Mirka sanders, registration required within 30 days. The tool is supplied with a 1/4" BSP female thread for air hose fitting.
Registration is required within 30 days of purchase.
The Mirka 2+1 year warranty applies to Mirka sanders, dust extractors and polishers. If a problem occurs with a Mirka tool caused by a manufacturing defect material or by workmanship; Mirka will repair your tool free of charge in accordance with the warranty terms.
