Pegas Double Skip Reverse Tooth Scroll Saw Blade
104453
104453
- Reverse teeth prevent splinters on the underside of the work
- Double skip teeth help prevent burning
- Particularly suited to cutting soft woods
- Made in Switzerland
- Blade length 130mm
- Packs of 12
This fast cutting blade leaves a smooth finish and is particularly effective in soft woods.
Pegas double reverse skip saw blades have the same basic tooth geometry as double skip blades except that they have a number of reverse teeth at the bottom of the blade. Reverse teeth prevent splinters from developing on the underside of the workpiece. This tooth arrangement results in efficient chip removal and helps prevent the wood from burning.
Thickness 0.46mm, width 1.14mm, overall length 130mm with plain ends, tpi 10.5/7.
