USE CODE: BLACKFRIDAY TO SAVE 10% SITEWIDE*
Pegas Reverse Skip Tooth Scroll Saw Blades
- Reverse teeth prevent splinters on the underside of the work
- Versatile, suitable for many materials
- Made in Switzerland
- Blade length 130mm
- Packs of 12
These blades have the same basic tooth geometry as skip blades except that a limited number of reverse teeth have been added to the bottom of the blade. Reverse teeth prevent splinters from developing on the underside of the workpiece because the top teeth do not cut entirely through the work. All operating parameters are the same as other blades. Overall blade length 130mm.
