PROXXON Diamond Grinding Bits
AX801346
AX801346
- For fine detail work
- Used on ceramics, glass, hardened steel etc.
PROXXON LGS/A Cordless Long Neck Drill Grinder - 10.8V (2.6Ah)From £199.98 £166.65
PROXXON IGS/A Cordless Industrial Straight Grinder - 10.8V (2.6Ah)From £189.98 £158.32
Show more
Show less
These bits have a consistent coating of diamond particles. The 2.35mm(3/32") diameter shafts are made from stainless steel. Used for engraving, fine detail work or grinding on ceramics, glass, hardened steel, semi-precious stones, porcelain and plastics. The ball point bits are supplied in packs of 2, in 1mm and 1.8mm diameter. The cylinder bits are 5mm x 1.8mm and the Lenticular bits are 5mm.
