PROXXON LGS/A Cordless Long Neck Drill Grinder - 10.8V (2.6Ah)
109501
109501
From £199.98 £166.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • 75mm extended neck for use in inaccessible areas
  • Use in slots and channels and make internal cuts
  • Strong die-cast aluminium head
  • Full-wave electronic speed control
The Proxxon LGS/A is powered by a 10.8V (2.6Ah) L-ion battery giving you performance comparable to its mains-powered cousin.
Built to last; the gear head is die-cast aluminium and the main body housing is glass-fibre reinforced POLYAMIDE. The soft grip insert offers comfort and improves control.
The LGS/A features a 75mm long spindle neck, allowing access into narrow spaces, for milling, drilling, grinding and polishing and making internal cuts. The compact design and lightweight (800g) make the LGS/A very easy to handle compared to standard size grinders. The continuously variable speed control 7,000 - 23,000 rpm allows you to work in a wide variety of materials.
It comes with a 6mm ER11 collet for 6mm shank bits (ER11 collets are available in a range of sizes for tooling with different shanks).
The LGS/A is supplied with a 10.8V (2.6Ah) L-ion battery Li/A2, a rapid battery charger LG/A2 and a 36g corundum grinding bit
All contained in a tough, high-grade polypropylene storage case.
