PROXXON HSS Micro Drills (Pkt 3)
- HSS drill bits
- High concentricity and accuracy
- Shank and bit made from a one-piece blank
- High hardness for the long life
- For drilling metal, non-ferrous metals, plastic, PC cards and wood
- All shafts are 2.35mm
- Supplied in packs of 3 per size
HSS drill bits made from specially selected steel. Method of manufacture ensures high concentricity and accuracy. The shank and bit are made from a one-piece blank. A high degree of hardness for the longest possible life expectancy. For drilling metal, non-ferrous metals, plastic, PC cards and wood. Work speeds: hard materials approx. 3,000rpm, soft materials approx. 8 000rpm. All shafts are 2.35mm, supplied in packs of 3 per size.
