From £115.98 £96.65
Low Stock
  • Oscillating motion ensures lack of vibration & kickback
  • Head of die-cast zinc, ensuring exact & stable housing for the working parts
  • For very tight spots, e.g. corners, sides & inaccessible areas
Customers Also Bought
This multi-use tool will sand, cut and rasp with the various accessories available. Using an oscillating motion the triangular head allows sanding in very tight spots, e.g. corners, sides and inaccessible areas, as well as the fitting of saw blades, scraper heads and files. The variable speed facility ensures the correct speed for every material, between 3,000 and 10,000 per minute. The head is die-cast zinc, ensuring exact and stable housing for the working parts, the main housing made of fibreglass reinforced POLYAMIDE. The oscillating motion ensures lack of vibration and kickback. Length 230mm, weight 630g, insulated to class II.
The OZI is supplied with 4 sanding pads of different grits (2 x 80grit, 1 each 150 and 240grit).
  • Variable speed facility ensures the correct speed for every material
  • 3,000 - 10,000 orbits per minute
  • Self adhesive sanding pads ensure quick changing & optimum usage
  • Simply remove & rotate through 120° for a fresh corner.
  • Sanding area 65 x 65 x 65mm
  • Supplied with 4 sanding sheets (2 x 80grit, 1 each 150 and 240grit)
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    4.50 4
