PROXXON VDE Insulated Slotted Screwdrivers
- Tested to VDE standard
- Safe for use on or around live components up to 1,000V AC
Axminster Workshop Centrotec Compatible Depth Adjustable Bit HolderSpecial Price £3.98 £3.32 was £6.98 £5.82 Save £3.00 £2.50
What does VDE mean?
VDE is a standard to ensure screwdrivers and other hand tools are safe to use when working with electricity. VDE takes its acronym from the German company Verband der Elektrotechnik, who are responsible for testing and certifying tools and appliances.
Recognised standard
VDE has become the recognised standard within the building trade throughout Europe. Seeing the VDE trademark on a pair of pliers or a screwdriver gives the user the assurance that it’s safe to use with electricity. Wherever you see the VDE mark you will often find a voltage limit, this indicates what voltage levels the tool is safe to work with.
Rigorous testing
Not just any tool can bear the VDE certification mark. All VDE rated tools are put through very rigorous testing to ensure the quality, construction, safety and even the ergonomics meet with the protective requirements of the applicable EC Directive.
The PROXXON insulated FLEX-DOT flat headed screwdrivers are tested to a VDE standard. They are safe for use on or around live components up to 1,000V AC.
