Restore Rust Remover Gel - 250ml
211834
From £17.48 £14.57
8 Reviews
  • Buy 10 for £15.73 £13.11 each
  • Buy 25 for £14.86 £12.38 each
  • Buy 50 for £13.99 £11.66 each
In Stock - Ready to dispatch
  • Restore rusty steel and iron components and tools
  • Gel for larger surfaces such as circular and bandsaw tables etc, extremely fast working
  • A biodegradable, non-toxic and water-based formulation
Use Restore rust remover gel to remove rust from larger surfaces such as circular and bandsaw tables etc. Apply using a household scouring pad (not supplied) moving gently over the surface until the rust is removed and the surface is left bright and clean. It is extremely fast working, in many cases the cleaning process taking no more than a few minutes. Please note that although technically classified as a gel, it is not a 'thick' gel capable of clinging to vertical surfaces - it is a thickened liquid.
3.90 8
