Rider 7 Piece Screwdriver Set
109416
From £49.98 £41.65
6 Reviews
  • Set covers the majority of common screws
  • Heat treated and blacked tips for wear resistance
  • Hexagon bolster allows use of a spanner
  • Stained and varnished European beech handles.
  • CrV steel blades, chrome plated for corrosion protection
  • Through blades with shock absorbing leather washer
These Rider wooden handled screwdrivers are made with care and attention to detail and come as a set of seven in a wooden presentation box. For those who like the feel of a traditional screwdriver, this set will cover the majority of common screws you are likely to encounter.
The handles are stained and varnished European beech. Three flats on the handle help transmit torque and also prevent the screwdriver rolling off your bench. The blades are CrV steel, chrome plated for corrosion protection. The blades pass through the handle to allow you to tap the screwdriver with a hammer for those occasional stubborn screws. A leather washer below the brass ferrule acts as a shock absorber. The hexagon bolster at the top of the blade allows the use of a spanner for those really stubborn screws. Finally the tips are carefully heat treated and blacked for wear resistance. Made in Europe.
Overall length between 180mm and 210mm.
Contents
Slotted 3.5mm, blade length 75mm, handle 95mm x 24mm.
Slotted 4.5mm, blade length 90mm, handle 95mm x 24mm.
Slotted 5.5mm, Blade length 100mm, handle 95mm x 24mm.
Pozi PZ1, blade length 80mm, handle 95mm x 24mm.
Pozi PZ2, blade length 100mm, handle 110mm x 31mm.
Phillips PH1, blade length 80mm, handle 95mm x 24mm.
Phillips PH2, blade length 100mm, handle 110mm x 31mm.
Quality tools made in Europe, supplied in a wooden box.
4.00 6
