From £3,499.98 £2,916.65
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
  • Enquire - contact us for a personalised quote
  • Simpler and safer cross cutting of sheet material
  • Vertical design saves floor space
  • Supplied with the fixed stand (110074)
Where space is at a premium, Safety Speed provides a great solution
Compact, portable and extremely accurate, the C4 Panel Saw allows you to easily cut precisely sized boards with no hassle, whilst taking up very little workshop space.
Vertical Design
The design of the panel saw means you'll save on floor space, making it easier and safer for cutting sheet material.
Increased Productivity
Simply and quickly switch from vertical to horizontal cutting, saving you time for more efficient working.
Switch from vertical to horizontal cutting
Longer Running Times
Thanks to the spring loaded counter balance system, you'll experience reduced user fatigue, allowing you to work comfortably and safely for longer.
High Quality Construction
Rust resistant zinc plated 1 3/4" steel guide tubes provide strength and accuracy to the motor unit, while the hard wearing 4 Nylatron rolling bearing system allows the head to operate smoothly and freely for excellent results.
The C4 vertical panel saw is a useful addition to any small or medium workshop where sheet material is regularly processed. Vertical operation makes handling of the sheets much easier as well as saving valuable floor space. The saw can be secured permanently to a wall or moved around with the aid of the optional wheels and either the fixed or folding stand. It can also be transported in the back of a van for site use. The saw unit with its 44.5mm depth of cut and 1,600W motor is fixed to a mounting plate which slides up and down the two guide bars, supported by a spring recoil device. Vertical cuts are made by positioning the sheet in the correct position on the frame and moving the saw blade down through the sheet. Horizontal cuts are made by rotating the saw unit through 90°, locking it in the correct vertical position and moving the sheet through the blade. Rollers on the lower rail ease the passage of the sheet through the saw and there are wheeled extensions available for the bottom rail to allow 2,440 x 1,220mm(8' x 4') sheets to be safely processed.
The saw comes fitted with a mid-way fence which makes the handling of narrower width boards much more convenient. The two horizontal timber supports on the mid-way fence are secured in place with quick release cam clamps which allow the supports to be removed in a few seconds when full depth sheets are to be cut. The mid-way fence is fitted with a precision stop for accurate repeat length cutting.
Other accessories available are: (a) a sliding dust extraction kit with a 6.5m hose which slides over the rollers at the top of the machine as the saw moves up and down; (b) a multiposition length stop which allows for up to eight pre-set lengths to be set and, (c) a hold down bar with support fingers and non marring rollers for use when cutting thin materials such as Perspex.
A fine toothed blade is now supplied as standard with the saw. An additional blade suitable for cutting non-ferrous materials is also available.Supplied with the fixed stand (110074).
  • Eases handling of sheets,panels,boards and worktops
  • Counter-balanced saw carriage for smooth operation
  • Quick change from vertical to horizontal cutting
  • 2,450 x 1,270mm (8' x 4') sheet cutting capacity
  • 44.5mm depth of cut
    5.00 2
