Shokunin Kataba Super Hard Saw Blade
- Replacement blade for Shokunin Kataba Super Hard Saws
- Impulse-hardened teeth for precision crosscutting
- Rustproof nickel plating for enhanced durability
- 0.6mm thick blade with a 1.9mm tooth pitch
- Backless design for unlimited depth of cut
- Suitable for softwood, hardwood, and plywood
The Shokunin Kataba Super Hard Saw Blade is a replacement blade for Shokunin Kataba Super Hard Saws. This professional-quality blade is designed for precision and efficiency in woodworking. The blade features impulse-hardened teeth that are precision ground for crosscutting, ensuring smooth and effortless cuts. The rustproof nickel plating enhances durability, while the 0.6mm blade thickness and 1.9mm tooth pitch produce a fine kerf of 0.93mm. The backless design allows for unlimited depth of cut, making it ideal for cutting wide boards or sheet material. Suitable for use on softwood, hardwood, and plywood, this blade is perfect for both professional and hobbyist woodworkers.
EAN Barcode | 5052511133987 |
