Souber Long Wood Drills for Lock Jig
AX830440
AX830440
- Extra long drills for the Souber lock jig
- Drills an extremely straight and true 10mm hole
- Available in lengths 950mm or 1,250mm
- Long drill arbor required for jig
Show more
Show less
These extra long drills are especially designed for the Souber lock jig to be used with the long arbor. 10mm in diameter in either 950mm or 1,250mm lengths, they will drill extremely straight and true from one side of a door to the other. N.B. Please ensure the drill is withdrawn at regular intervals to clear waste material.
